Company Logo (800) 853-2651 Shop Now
WD-45 Question
Leonard Dacus
01-31-2013 17:09:51
Have been working on my WD45,Engine has more viberation than normal. No different than has been for a number of years,sure would like it to better. Have D-17 same engine 226 gas in both tractors D-17 runs as smooth as a calf sucking.
Do I have a flywheel balance problem,Just wondering what some of you think.
Leonard D.
BushogPapa
02-01-2013 11:23:34
 Re: WD-45 Question in reply to Leonard Dacus, 01-31-2013 17:09:51
May be that the Clutch-Plate has lost some lining on one side or a spring may have broken and come out of the Pressure-plate..???
Ron.
old
01-31-2013 18:00:25
Could be a number of things. Flywheel out of balance or a bad crank shaft pulley or even a weak cylinder or what would be bad is some one who took mismatched pistons and installed them.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
