Re: WD snap coupler plow
Larry B
04-01-2000 05:06:00
THERE SHOULD BE A CRANK ON THE PLOW THAY WHEN CRANKED ONE WAY OR THE OTHER WILL FORCE THE PLOW TO GO DEEPER.
ARTY / MO
04-09-2000 09:38:50
 Re: Re: WD snap coupler plow in reply to Larry B, 04-01-2000 05:06:00
LARRY'S RIGHT ABOUT THE CRANK. A PLOW WILL SEEK ITS OWN LEVEL, SO IF YOU DRAW THE REAR OF PLOW UP HIGHER THAN FRONT, IT WILL HAVE TO DRAFT DEEPER TO BE LEVEL. THE 3 PT. FULLY MOUNTED TYPE ARE ADJ. BY SHORTING THE CENTER LINK. GOOD LUCK & HAPPY FURROW FILLIN! ARTY
