Company Logo (800) 853-2651 Shop Now
Good spark plugs for WD45
Mean green
01-27-2013 15:11:48
What are good spark plugs for a gas WD45? Champion or Autolite? Numbers? I know I have had better luck with the Autolites on my John Deeres. Thanks for the help.
KEN IND.
02-23-2013 12:30:01
 Re: Good spark plugs for WD45 in reply to Mean green, 01-27-2013 15:11:48
I run Chanmps in my 3 red ones 2 flambue red ones and my 1 orange and NEVER had a problem with them running wise or when tune time was in getting them out, Kenny.
Ahod
01-31-2013 17:15:23
i use a-c plugs in my d-17 and msd ignition and it eliminates all the problems your talking about
Kip-Utah
01-27-2013 21:41:23
Your WD45 most likely has a distributor (battery) ignition. If so and it's in a good state of tune and not an excessive oil burner I would suggest Autolite 303. But 295s also work great and is what you should use if by chance you are running a magneto. Kip
Ted in NE-OH
01-27-2013 15:58:52
Autolite 295
old
01-27-2013 15:17:40
I have champs in my WD45 but could not see the number on them. When and if I replace them I will go with auto lites
black
01-27-2013 15:37:44
 Re: Good spark plugs for WD45 in reply to old, 01-27-2013 15:17:40
Old; Is there a problem with your champs ? or is your preference Autolites . My wd45 has champs and so far she pulls and parades good -- don't know the plug # off hand
old
01-27-2013 18:06:19
 Re: Good spark plugs for WD45 in reply to black, 01-27-2013 15:37:44
Now days the Auto lites seem to work better with this crap gas we have now then the champs do. But the champs I have in this WD45 are the same ones that where in it back 10 years ago when I got the thing and as long as she runs well and does what I want I'll leave them there
BushogPapa
01-27-2013 18:12:58
 Re: Good spark plugs for WD45 in reply to old, 01-27-2013 18:06:19
Maybe you just got real lucky and got a GOOD set of Champs... Now..hope they come OUT when you want to change them..!!
Ron..
old
01-27-2013 18:26:24
 Re: Good spark plugs for WD45 in reply to BushogPapa, 01-27-2013 18:12:58
I have had them out a few times doing what I call a poor mans tune up. I clean then regap them and put them in a different cylinder and go with it. It has had a hay rake on it for the last 2 or 3 years. Walked by it just the other day and turn the gas on and it started right up and it has been sitting in the filed since May when I did the hay this year
black
01-28-2013 17:19:13
 Re: Good spark plugs for WD45 in reply to old, 01-27-2013 18:26:24
Ya , I'm always afraid of getting dirt in the cylinders , so I blow air to clean the head before removing the plugs . Your right Old , my wd45 also sits for months and fires right up -- a little choke and away she goes . I just have a straight pipe and I love the bark from that crater engine.
BushogPapa
01-27-2013 19:05:32
Using Champions in my old 390 Ford taught me to always use "Never-Seize" on each and every one..!!! Had the same experiences with them in a JD..
About twisted some off, getting them out..
Really thought I would at least bend the 1/2" breaker-bar..
Ron..
old
01-27-2013 20:51:00
 Re: Good spark plugs for WD45 in reply to BushogPapa, 01-27-2013 19:05:32
Never had much problem with plugs sticking in the head but them I do not over tighten them. Shoot some times I have the opposite problem and forget to tighten them enough and have them blow out and when that happens they can be hard to find LOL
BushogPapa
01-28-2013 14:14:40
 Re: Good spark plugs for WD45 in reply to old, 01-27-2013 20:51:00
Something like that might give ya a heat attack..!!! I do have a habit of getting things "MAN_Tight"...don't usually have bolts come loose either, but those Champs sometimes seem to seize in the threads and really can be severely hard to wrench out..ALL the way out..they Squeak and Squal all the way, each time you force them to move and you'd bet there were not going to be any threads when you get it out...
Like I said..I USE "Never-Seize" religiously on sparkplugs..!!!
Ron.
old
01-28-2013 14:38:27
 Re: Good spark plugs for WD45 in reply to BushogPapa, 01-28-2013 14:14:40
Learned many years ago to tight is as bad if not worse then not tight enough.
old
01-27-2013 18:26:20
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: good hydraulic unit for JD 50/520/530 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
