Company Logo Shop Now
D17 hyd puzzle
Ron muhlenkamp
01-19-2013 12:43:52
Last year bot a d17 series I. Hyd worked, but wouldn"t lift a snap couple plow Added a two way valve with a shutoff and it worked fine with a wheel disc Put gauge on line, it built slowly to 1600#. Replaced pump with a used one the owner swore worked 100% had used it with 3 pt bushog. After replacement, the pressure hit 2500# 1 time but woudnt repeat Cycled a few time. now with the shut off valve open, the arms will lift 200# ( me) chattering all the while, and will drop. With the shut off closed, will lift me and chattering and will stick at top. If I open valve to drop an inch or so then close it will continue to drop Reads almost nothing on gauge Thoughts?..
Diydave
01-20-2013 05:48:52
 Re: D17 hyd puzzle in reply to Ron muhlenkamp, 01-19-2013 12:43:52
Pump on that tractor should be High pressure system, 3500 PSI, 4GPM. Likely a pump problem, or cams that run the pump are worn away.
budanut
01-19-2013 18:07:19
Since all oil goes through the lift arm cylinder, you might check for bad cylinder or the hose going to the cylinder might be bad.
old
01-19-2013 14:55:40
Fluid low or wrong will cause a chatter.
Latest Ad: one pair john deere 6030 open station engine side panels new old stock rare rare rare [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
