allis B parts
You can get them from your AGCO dealer... but if you know anything about bearings and seals , you will find they are standard items used my multiple companies. you can get them from your local bearing supply like, Motion INdustries, Berry Bearing, etc. You must need the number off the race.
I was looking for a seal that goes to a ross steering sector. No number on seal and the local AGCO dealer says they are no longer available. Any ideas of someone with knowledge and part numbers.
I was told it showed NA. No number but I will take an ID and an Od and go to my local NAPA. unless someone knows of a good source of Allis Chalmers parts.
I dont know the seal number, but i have used the OD- ID trick a lot of times and look up the numbers in my seal book. NAPA should be able to do that also.
I have a number that some one wrote in a old parts book. cr9878 the id is 1" and the od is 1.5" does this match any thing in your seal book?
