4 yrs ago I split the tractor, and installed a new clutch in it. I put the 3/32" (or thereabouts) shims back in it, that were originaly there. After trying it out, it had excessive creep, in gear with the clutch released and I didn't like that, so I opened it up again, and added a .010 shim to all 3 points, closed it back up, and still had some creep, but it was better. Now the handle falls out of engagement, at the worst times, like loading manure on a slick surface, when stopping momentarily, means being stuck. I opened it up yesterday and pulled the 3 .010 shims out, and went back to work. It still falls foreward at times, and is only a little bit better.When I read about removing the shims to get more life from the clutch, does that mean that I should remove the 3 thick shims? Will the clutch still work, with those removed?
