Company Logo Shop Now
Head Gasket
Country Bob 74
10-27-2012 08:33:38
Any advise on replacing a head gasket on a WD45
CTucker
11-01-2012 16:06:31
 Re: Head Gasket in reply to Country Bob 74, 10-27-2012 08:33:38
Might want to replace the core plugs in the top of the head while you have it apart. They have a tendency to rust thru from the inside and let coolant leak out into your oil sump :(
BushogPapa
10-27-2012 10:36:19
Replace the radiator hoses while it is apart..!!
Pretty straight forward.. about the only problem I have had is getting the plate between the 2 rear head bolts to seal..
Use some sealer on the Push-rod side of the head gasket..they seem to seep on that side for a while if you don't.. Might be a good idea to knock a freeze plug of two out and Flush the water jacket out while you can.
Ron..
BushogPapa
10-29-2012 10:20:33
 Re: Head Gasket in reply to BushogPapa, 10-27-2012 10:36:19
NO, you do NOT need to pull the engine for a Head Gasket... You WILL need to remove the top sheet metal "Hood".. That comes off easy, with a few screws up near the radiator and the "Screw-clamp" around the gas tank.. Lift off the air inlet cover and the hood will lift off.. After that, it is a straight-forward head Gasket change.. If you ever want a new muffler, remember, ONLY a "Nelson" Muffler sounds "Correct"..
Ron..
BushogPapa
10-29-2012 10:19:53
Ron..
Country Bob 74
10-29-2012 05:14:23
Will I need to pull the engine to replace the head gasket?
BushogPapa
10-28-2012 16:56:49
When installing the Int/Exh manifold, I rub Hi-Temp Silicone into the white rings, slip them on the manifold runners, stick the metal cups on them, then slip the manifold in place..keeps everything together better..!! I think it makes the gaskets last longer too.. Use "Never-Seize" on the Manifold nuts.. I like to add a Hardened Washer under each nut.. Might as well check or replace the thermostat while you have it apart..
Ron..
Country Bob 74
10-28-2012 13:54:41
Thanks so much, can use all the help I can get. I'm not much of a mechanic.
Country Bob 74
10-28-2012 13:54:41
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
