Company Logo Shop Now
General Carburetor Rebuild Question - Needle Valve
cpgdude
10-15-2012 09:50:35
third party image
Hi folks,
I'm rebuilding the carburetor to my 1952 Allis Chalmers WD. I'm reassembling the carburetor, and need some advice or direction. When I reinstall the needle valve, I noted that my rebuild kit came with a little wire assembly that looks like it goes around one end of the needle valve and the wire ends install on the float. Is this correct. How should you install this little wire assembly? Or do you need it at all. It doesn't show in the A/C parts book. The picture shows the little wire assembly on the right side. Thanks in advance!!
rustyfarmall
10-16-2012 08:56:03
 Re: General Carburetor Rebuild Question - Needle Valve in reply to cpgdude, 10-15-2012 09:50:35
Here's another tip. Use some aerosol carb cleaner to thoroughly clean both the needle and the seat, blow them dry, and then spray some silicon lubricant on the needle and inside the seat. Doing this will prevent the initial sticking, and you probably won't even need that little clip.
Incidently, those carb kits a very universal these days and one kit is designed to fit a multitude of different models. If just one of those models needed that little clip, then that is what was put into the kit, and the carburetor YOU are working on may not even need it.
John B.
10-16-2012 07:16:41
Definately use the little spring. You can save yourself a lot of headaches in a year or two.
cpgdude
10-15-2012 15:17:11
Thanks for the replies! That was very informative. I appreciate your taking the time to educate me!!
old
10-15-2012 11:45:21
Yep the spring is used to keep the needle from sticking in the seat so you get a + opening when the float drops. Do you self a favor and drop the need in the seat and tap on it with a small screw driver handle before putting the carb together that will put a set on the tip so it will seal better
Ted in NE-OH
10-15-2012 10:38:50
The needle valve has a new style neoprene tip and the spring is used to release the needle so it does not stick. The older style needle valves did not have the neoprene tip and did not need the spring
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
Latest Ad: 3pt hitch for ford 3930 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
