D14 in J-yard- most likely failure?
Anonymous-0
Saw a D14 gas in the j-yard. Tractor seemed complete. Any idea what the most common failure would be? Was thinking it's be nice to have a little bit bigger than the 'B'.
Will that block bolt into my 'B'? DickL has been too inspiring...
First thing to go was the block. Drain cock was not in an obvious to get to locale, plus there was not a lot of metal between the cylinders (maybe a bored out smaller engine). Often cracks between cylinders.
Any cracks between the lower webs are not a "Death Sentence" for the AC Blocks..
They can be "Pinned", or resistance-welded to like NEW condition..
Both of our WD-45 tractors were Resistance-Welded and "Pinned" at "Columbus Col-Weld" in Cols, Ohio..
Guaranteed not to crack again..
It is amazing what some people Scrap..it may be a perfectly fine, running tractor..
Ron..
