CA engine build
OldMoIron
I was wondering how I could build up a CA engine for little more grunt. Can I put a D14 engine sleeve and piston kit in it?
Not really unless you bore the block as the sleeves are larger in outside diameter and tig weld the crator full to make flat top pistons.
The over bore kit is 3 7/16 for the CA and if you remove .200 from the head along with porting it you will get about as much as you can without spending a bunch of money.
