Company Logo (800) 853-2651 Shop Now
AC 185 Diesel
cuttman
07-05-2012 18:00:31
What would make an AC185 hunt or surge for fuel when at an idle position. When you speed it up it quits hunting. It's my friends tractor and he said it has a new fuel pump. Thanks Gregg.
cuttman
07-08-2012 08:04:20
 Re: AC 185 Diesel in reply to cuttman, 07-05-2012 18:00:31
Thanks for the replys, I will give him the advice. I think I'm gonna suggest taking back to dealer and let them look at it.
4020guy:
The pump was professonially rebuilt supposedly.
charles todd
07-07-2012 22:40:08
If it has a Roosta-Master, I think it is a pump issue. My 180 does this sometimes. Sometimes at idle, sometimes at rated speed. I think it is the rubber coated disc in the injector pump is coming apart. I plan to pull all injectors and pump to have them overhauled. Sorry, it's about $1000 to do all of this. $600+ for just a pump.
CT
farmer boy
07-07-2012 10:07:43
Our 185 does exactly the same thing. It will smooth out as you increase the rpm(completely smooth at around 1200 rpm?) but never stalls and still has decent power for idle. I've read that there is an o-ring in there that wears down but don't know for sure.
4020guy
07-07-2012 03:49:18
When you say new fuel pump, do you mean injector? Sounds like the plastic drive coupler inside the injector pump is starting to wear away. My 190XT started to do this. My former AC dealer replaced the ring inside for less than 200 dollars[r&r pump myself]. Best to do soon before plastic pieces start plugging stuff up inside the Roto-Master pump....Ron
massey333
07-06-2012 12:19:50
This may not be the answer you want,but I think that is the nature of the beast(185s).They have -had a very touchy governor and everyone I have been around(Dads new to 5000Hrs plus others)did the hunting bit under 1100-1200RPM but were fine over that.XTs-200s-7000s didn't do it but the 185s did.I"am not saying something can't be wrong but that was one quirk the 185s did have.
180doug
07-06-2012 05:55:04
Check all the connections on the fuel lines, , they have rubber seals that get damaged and suck air, , id start at the tank for good flow, , then the filter and the connections, , but i bet its the rubber seals at the connections
Diydave
07-06-2012 03:17:57
Water in the fuel, would be my first guess. Have you checked the filters???
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: good hydraulic unit for JD 50/520/530 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
