WD rear wheel bearing
Anonymous-0
I took the wheel bearings off my right side rear of the tractor. The hub was sloppy up and down. I took it apart and found that the bolt was loose apparently for a long time. What im wondering is where would i find the big flat washer that goes underneath the bolt and lock washer. Mine is wore from running loose. Also wondering where i would find some shims that go in there.
