Company Logo Shop Now
1950 B Wire problem
Will Dean
04-22-2012 14:52:42
I have a 1950 AC B that I have replaced the wire harness with a new one. I followed the wire sch and i have 1 wire I can not figure out were it goes. It is a black wire that comes from the switch box to the altenator. It has a small terminal eng at the switch box and a big terminal end at the altermator end. Can anyone help me?
Will Dean
04-22-2012 17:09:57
 Re: 1950 B Wire problem in reply to Will Dean, 04-22-2012 14:52:42
My mistake. My AC B did come with a generator and not a altenator. I mistyped the info.
chalmersbob(pa)
04-22-2012 19:23:08
if you tractor had the original wiring, it would probably go from the resistor on the light switch to the F terminal on the generator. Bob
old
04-22-2012 15:04:23
Your problem maybe as simple as you have the wrong wiring harnesses since the tractor came from the factory with a generator on it not an alternator so it would not be wired correctly to work with an alternator
Latest Ad: Farmall 450 400 factory wide front End, nice tight front end, no welds, 1250 obo [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
