BANDITFARMER
After some time going through the tool boxes I found my hydrolic pressure gauge. With the tractor running at 1500 rpm it gose up to 2000 psi when it tops off then starts falling down to a 1175 psi and holds. The add on 3pt will hold all day in the up position with a 6ft bushhog hanging on it. The transprot valve looks like it has been off the tractor at some point or may have been changed out, I just dont know. By the serial# 43xxx its a series 3 (early) and dose not have a hydrolic filter on it, So I think it has the series 2 hydrolics on it. Dose anybody have any ideas of whats going on with this D17 not wanting to raise the cultamulcher? The cylinder is a 3 inch AC one way ram, It has no problem picking up a IH 370 12ft disc. Bandit
