how do I find the serial number on a AC WD 45
stand at rear of tractor seat is on the right brake housing, serial number is on left brake housing.where the lift arm bolts to tractor there will be a flat spot that has the number on it will start out wd then number , might have to scrape some paint off.
See photos - assuming they come thru ok - the more common is the white area in the color photo, but some early tractors have at top of brake housing. It should start WD even for WD45 but s/n break is at WD146606 which was last WD and WD146607 which was first WD45.
trying pictures again
