This is a 2 part question...Weather below freezing yesterday morning, Started the 190 up from sitting all winter, had no hydraulic pressure anywhere, ie: steering, clutch, loader and PTO. Checked the dipstick and found emulsified oil on stick. Later in the day after temps warmed up, went back out and tried again. This time everything worked as it should except the PTO. My question is, how do I get rid of all the emulsified oil without excessive cost of oil by repeated flushing of the system? Also I was informed the PTO has not worked in about 5 years. How do I troubleshoot this PTO system? I know that the hydraulic pump is 2 port, does the pto have a dedicated port? I have read that the pump housings wears out and system pressure drops with the wear. What kind of pressure should I see on the hydraulic system and where is the best place on the tractor to get these readings?
