Getting a G in the shop with poor hydraulic performance, and wonder if someone can help me dignose this beast. Hydraulics work, but only move an inch. I have adjusted what looks like a pressure relief valve in & out, no change.
It is not noisy, as in running out of oil.
I post a photo that shows the pump area. I did not fiddle with any other adjustments or drain plugs.
Does the pump share the transmission oil as a reservoir? The oil level seemed to be up to the required level in the trans.
Any advice appreciated. I have a manual on order, but I"d like to start thinking about it now.
