Glen Higgins
New User
Thanks to old,steve & ted for their replies. I have a allis chalmer B. When I bought the tractor it had a one wire alternator and 12 volt battery. The battery was bad had to replace. I used it for about 2 to 3 mos. Then I had to charge the battery. When it comes to tractors ignition and etc. I am not good at it. Make a long story short I replaced the alternator with one wire. When I did this I found the alternator wire was hooked up to nothing. The orginal switches were removed. There is a toggle switch one wire coming from pos. side of battery the other coming from switch goes to coil-not sure. It was suggestied that I run #12 wire from alternator to ammeter from ammeter to starter. When I tried to start it would't fire. HELP Glem Ga.
P.S. I haven't tried to start it today because I want to be sure I have the toggle switch wired correctly. Thanks
