Allis B Steel wheels
Hi. I need a drawing or some pics of an Allis B steel front wheel. I got one in need of serious restoration but the centre is non existant so i need info as to how to rebuild it.
Anyone able to help would be really appreciated. Mike
If the center is gone I'm not sure what you would do, it's the rim that is usually missing. Here are pics of B/C front steel.
Are you missing the spokes, the hub, or the grease covers? I think I have a correct set of covers around here. If memeory serves the WC/WD parts don't work on the B/C.
Thanks very much for info so far. OK. Here is the full situation. I have got the spokes and part of outer rim. What I really needed to was how the centre was made. I was hoping the cente bolted to the normal hub . But I can see thats wrong I see that it appears to be a casting. So I shall use this one and make a new centre to bolt on. Someone care to tell me the exact diameter. i hate to see something as important as these old parts just thrown away. I'll try to upload some pics of a pair of rears I.ve just finished even made a batch of square headed bolts I think thats what they left the factory with. Thanks again Mike
Looks like you did a nice job on the rears but I don't know how you would make the center for the fronts. There are quite a few B/C's out there with rubber tire rims welded to steel wheel centers, if you could find a pair of those you would be set. The dimension of the center is 7" diameter and 4" wide. Hope that helps.
Thanks thats a good start point. Is that 7" ID or OD. What I'll do is try to re-jig the rim to ensure that its 'true' then go from there.
So final question at this stage what is the OD of the actual wheel rim and the width. Thanks again. Mike
Thanks again. I'm seriously thinking of making some new ones(LOL). I certainly can't cast new centres so I guess I'll have to have a clear thought or several on that. No doubt I'll have more questions on this one. Mike
sure looks to me like you could take a 2 inch heavy wall pipe and turn the ID both ends to put bearing outer race into it. The outside looks like a piece fo 6 inch heavy wall pipe. THe two weld together with a flat plate like a washer... Looks like a good weekend project to build one !
Thats generally my thoughts at the moment. Just need a bit of refining then I'll give it a go. My actual way will be probably heavy wall pipe with a half inch flat plate welded inside then drill it to bolt onto existing hubs (drill it first of course). Time is not essential. Mike
Mike, nice repair work on the rears. Are those the original cleats? Every B or C with rear steel I've seen has solid cleats. Is it possible yours are from a WC? Either way, nice work... I have a set that needs almost the exact same repair. And I could use one of the solid cleats if you happen to have any.
