Transport valve
Anonymous-0
Just purchased a transport valve for my WD45. I did not think to ask the gentleman, which line goes where. I am referring to, looking at it from the rear of the tractor, which side should the line from the pump (pressure line) go?
Thanks for your help.
Fred
My books are in the shop, can check tomorrow, but CRS says the pressure line is the front one. Other one needs to return oil to a sump.
Here"s my setup on the D17- front line is pressure line.
In the second pic, the double remote hoses from the aux remote are in the way....but the elbow in the first pic is the return from the aux valve, thus the one in front of the elbow is the pressure feed to the transport valve. BTW, the aux valve has a 15-1800 psi relief valve, so I can run a low pressure cyl with the high pressure AC system. Typical use was a hyd rock wagon or pickup cyl on a NH baler.
