Looking for G belt pulley assembly
Found out the other day that the G I bought doesn't have a belt pulley assembly, which is what I need to start some other old engines by belt
I was woundering if anyone had one or knowedge of where to get one. I would prefer a flat belt pulley to come on the assembly but its not a big deal if id does not.
Thanks,
Keven McNeice
Get your checkbook out. A complete assembly just sold on e-bay for around $350 which is about the going rate. You can call Matt at 612-508-4759, he has one with a flat pulley for $300.
If you don't have hydraulics you will use the long one which is more common (and cheaper) than the short one which mounts up to the hydraulic pump.....
Ah good point, I do not have hydraulics (1st production year G SN:1192 ) so I will make sure that its what I get. Are you sure there is only 2 types?
