Company Logo (800) 853-2651 Shop Now
bearing crush
jrm1
01-18-2012 06:41:55
I pulled pan off my wd45 due to oil leal. The engine was rebuilt and has several hours on it. I know now the rear main crush was set to tight. The shell still looks great and clearance in middle of spec. Since the engine has hours on rebuild should I file shell to obtain correct crush or leave it alone?
DickL would you please give your advice or someone who has a lot of exp. with shims.
Dick L
01-18-2012 18:52:14
 Re: bearing crush in reply to jrm1, 01-18-2012 06:41:55
If you have .002 to .003 and the crankshaft is not dragging from the crush then I would leave it alone.
The only time you need to file is when the bearing crush has caused the bearing halves to pinch in at the ends and press on the crankshaft which causes the crankshaft to bind on the bearings while still having the proper plastigage reading or a greater reading.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
