Anonymous-0
Allis B. Was a running tractor 3 years ago. Would not turn over with crank or electric start. Was hoping to free it up at little or no trouble. ATF in holes for a month, no go. Pulled the valve cover, exhaust valve stuck open on #2, bent exhaust push rod on #3 (like in a Z shape!). Pulled the rocker shaft, still stuck. Pulled the head, #2 and #3 exhaust full of bees! #2 exhaust valve stuck open abut 1/4". Got it to move but stull sticky so assuming it's bent. Cleaned bees out of the cylinders, no real rust, Kroil'd, tapped, pounded, could get #1 and #4 to move around in the bores, some movement of #2, but no going up or down.
Dropped pan, no obvious issues other than oil pump pick up screen coming loose. Had some fun pulling cotter keyed rod bolt nuts, those things probably had 150lb/ft torque. Wooden rod, tapped #1 and #4 out no problem, look pretty good, a little worn but certainly not stuck. #2 and #3 are on the up stroke, crank is at that place where there is not enough room to get the rod end between the crank and block. But, I tap #2 up so the rod is loose on the crank. Motor is still stuck. Tap on #3, piston move up, now crank is free to swing.
NOT!
Finals are free, I can roll the tractor around in neutral, locks in any gear. Cannot spin the crank with hand crank or starter, any gear or neutral, with the clutch locked out.
If the clutch was stuck I still should be able to spin the crank and shaft. If the trans was jammed I would suspect that it wouldn't shift into all the gears, or that it would be locked even in neutral.
I'm kind of stumped. Guess my next step is to split the tractor and see if I can spin the crank with the drive shaft off. But before I do that I thought I'd ask for any other ideas.
NOT!
