Anonymous-0
I am struggling with shimming the crank and rods on a WF, 201 gas. The manual calls for 4 shims in each location initially. How thick were the shims originally? I have some of the shims that wnere in the engine but i got this engine in a box, dissassembled. The shims were all 0.003". The shims from AGCO were 0.009" and only call for 1 shim in each location. The book calls for 0.0015" crush on the bearing shells, which is impossible with .009" shims. On the rods, 1 shim gives about 0.004 crush, is this okay? The next problem is there is nothing to align the caps and rods, the bolts are not a snug fit. When i tighten them to the crank, they may end up tight on the sides even if the oil clearance top and bottom is good. The mains seem the same, when i get the oil clearance down to 0.002" (Checked with plastigage) and tighten the main caps, the crank is tight and wont turn. Im not having a great day. Any one ever done one of these?
