Replacing seals on AC175 lift arms
Anonymous-0
In trying to repair leaking seals I was able to finally remove rod on cyl lift arms of AC 175. Since the front pins were frozen I removed rod and seals with cyl staying on tractor. While I had to leave job early the rod resisted going back into cyl. Before going back and forcing rod into cyl and causing damage I will ask is there any trick to getting rod back into cyl tube. Any help would be much appreciated by this rookie mechanic.
