Re: Implements for Allis Chalmers WD
John C-IL
03-10-2000 19:24:03
I have seen blade, plow, endloader, row-crop cultivator and plow. Can't say on the others. At this time I don't know of any but if you will e-mail address info I will keep an eye out as I do for same stuff myself. Also need to know where you are located. John
Dan
03-13-2000 19:37:08
 Re: Re: Implements for Allis Chalmers WD in reply to John C-IL, 03-10-2000 19:24:03
A-C made all of the machines you spoke of and I would say to stick with AC equipment. It is getting somewhat harder to find but I just bought a 3-14 plow for $50 tonight. I know where there is a loader that will fit but don't know where you are. I am located in northeastern Iowa.
Rich
03-16-2000 17:01:37
 Re: Re: Re: Implements for Allis Chalmers WD in reply to Dan, 03-13-2000 19:37:08
Dan,
Is there a reason you would stick with old out dated equipment. Is it just for the sake of originality? Are the older implements better made and therefore last longer? I'm a rookie so these are legitimate questions. I was thinking of buying an older WD or WD45 type tractor and fitting it w/ a three point hitch so I could use equipment that is more readily available(and more easily repaired with parts that are readily available). Thank you for you comments.
Rich
