wd 45 fenders
Only if you have the much higher mounting brackets, Even then the 45s 14.9 tires might be into the fenders. You'd have to be careful not to narrow the wheels in too far.
I think the WC and WD fenders are the same. The WC just has one extra bracket to brace them down to the rear axle housing. I assume you are talking about a styled WC.
AaronSEIA
No- the clamshell might be the same, but the mounting brackets are different. WC is one style, WD and WD45 are a different style. (assuming you are not talking unstyled WC fenders, which are certainly different).
That is a yes no and sort of thing. The WC fenders have an extra brace on them. I know they will in fact swap but not be 100% correct since I have a set of WD fenders on my W Speed Patrol
