Company Logo Shop Now
pompe a eau allis-chalmers france help
moriano
12-08-2011 02:53:36
hello all first
I m'escuce in advance for my bad language.je introduce myself I'm French living in France and I am owner of an Allis Chalmers that nome home fd3.0 of 1961 I have a problem to pump water cassez.je is no longer able to find parts for my tractor in France is an Allis Chalmers engine 4 cylinder diesel. I went through your forum and I can not determine the model you might get m 'help? I would like to post pictures but I can not search my email address jfmoriano@gmail.com.je a water pump and all the information on my tractor model.ce work even a month ago and the pump a break when I want a pump or a repair kit if a kind soul can help me I shook grateful. friendship and all cordially Jean Francois.
steve(ill)
12-08-2011 15:56:18
 Re: pompe a eau allis-chalmers france help in reply to moriano, 12-08-2011 02:53:36
you might also check with a local machinist shop or rebuilder of auto parts. Most water pumps can be taken apart and a new mechanical seal installed. The bearing might be reusable as is. Seals are generic by size and would not need to know the manufacturer of the pump.
Tramway Guy
12-08-2011 13:30:25
After looking at a few pictures via Google, I thought maybe it was a FD5.0 which should have been equipped with a Perkins P4 engine.
However all the FD5.0 had frame rails each side of the engine. This one does not, which makes be think it has been repowered with something other than an original A-C supplied engine.
I suggest removing the sheet metal and take pictures of the engine from various angles.
jfmoriano
12-13-2011 03:28:46
 Re: pompe a eau allis-chalmers france help in reply to Tramway Guy, 12-08-2011 13:30:25
Hello, as promised I posted the photos thank you again. jfmoriano friendships
Tramway Guy
12-15-2011 04:54:50
 Re: pompe a eau allis-chalmers france help in reply to jfmoriano, 12-13-2011 03:28:46
Where did you post them? I don't see them.
jfmoriano
12-13-2011 04:00:37
ok?
moriano
12-08-2011 22:26:05
hello all
I will post other picture Monday on the engine there are 289 engraved I will take pictures of the pump also cordially thank you for your answers jf.
ps: Sorry for my bad language.
El Toro
12-09-2011 04:53:10
 Re: pompe a eau allis-chalmers france help in reply to moriano, 12-08-2011 22:26:05
Your English is very good. Hal
Tramway Guy
12-08-2011 08:08:19
FD3 should have a Perkins engine, model 4.99 if it is liquid-cooled. They also used a 2-cylinder Vendeuvre 2-cylinder engine, but that is obviously not what you have.
Perkins parts should be available.
moriano
12-08-2011 08:15:42
 Re: pompe a eau allis-chalmers france help in reply to Tramway Guy, 12-08-2011 08:08:19
hello
First of all thank you for your response. it's not an engine is an engine perkins allis challmers I look at perkins and my engine is substantially different and the water pump is totally different. cordially
YTSupport
12-08-2011 08:01:37
 Re: pompe a eau allis-chalmers france help in reply to Bob Bancroft, 12-08-2011 02:53:36
Jean,
I would bet you have an FD-4 or FD-5.
The engine does not appear to match the D12 Diesel sold in the US based on Oil and air filter placement, and exhaust manifold differences. AC had manufacturing facilities in France at that time, and may have built a different design than the US models. Someone please correct me if you have information to the contrary. That would locating parts very easy.
Hopefully someone else will have more knowledge on the European models.
If there is any change that minor parts were interchanged, casting numbers may determine that. The chance seems remote though.
Thanks,
Chris
garage13
12-08-2011 03:53:30
At the bottom of your message post window there is a link to click, it says upload photo. I think we are going to need some pictures to help you out.
JD
moriano
12-08-2011 06:22:32
 Re: pompe a eau allis-chalmers france help in reply to garage13, 12-08-2011 03:53:30
third party image
thank you for your response and I will try to put pictures of my tracteur.cordialement
moriano
12-08-2011 07:22:25
 Re: pompe a eau allis-chalmers france help in reply to moriano, 12-08-2011 06:22:32
third party image
This is another picture I hope this will tell you something. thank you
DiyDave
12-08-2011 10:08:30
 Re: pompe a eau allis-chalmers france help in reply to moriano, 12-08-2011 07:22:25
If you have more pictures, of the sides of the motor, and the top, with the hood off, perhaps someone can identify the motor. If your water pump is complete, and not leaking, there may be a way around the problem. Some of the hot rod guys, use an electric water pump, that goes in place of a water hose, but there are some size and shape of hose restrictions, on those. I would have to see the water pump in question, and how it fits, on the motor, before saying more.
jfmoriano
12-13-2011 03:38:25
 Re: pompe a eau allis-chalmers france help in reply to DiyDave, 12-08-2011 10:08:30
tank you
moriano
12-08-2011 22:30:56
hello I put pictures of the pump Monday it will be simpler thank you for your attetion
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
