Just got this tractor and wanted to put on new amp gauge. But, I found the wiring is different from the manual. This tractor has a negative ground-I thought all Allis's were + gnd. Also the regulator had 3 terminals on the bottom and one on top. On bottom was Bat, F, L., and on top was black wire going to generator. I'm guessing the top terminal is Gen. The L on the regulator wasn't used. It looks like the big red wire from regulator goes to + post on amp gauge, not neg as the book says. What difference does Neg. ground make in installing amp gauge and does it really make any difference whether it is pos. or neg. ground.
