190xt III diesel valves?
charger66
Hey guys i' m trying to pull the pump off my 190 xt III. I pulled the valve cover as it is leaking and to make sure I got the #1 cylinder in the right spot to pull the pump..........My question is which valve is the intake?
The way the manifolds bolt up it seems hard to tell?
Is the intake the front valve or the rear valve? thanks!
Just put the pump on the same way you took it off. There is a mark on shaft and one in pump and make sure thay are are together. Real simple, don't have to pull valve cover.
Bob
