My 190 has a loader on it that is controlled by the factory dual spool valves. I"d like to use the factory valves for running other attachments. In the past I"ve just removed the bucket and used the valve that controls the tilt for my attachments.
Right now, the pressure line goes into the factory valve then through a filter and then back to the housing. Could I add another valve in between the factory valve and the filter? There is a steel pipe that connects the two right now and I would replace that with some flex hoses that would run into the cab for controlling the loader.
I don"t see any problems doing this, but thought I"d ask the question to get some other opinions. I"m thinking I could do this for $300 to $400.
Thanks
Jeff
Thanks
Jeff
