nl00sb
wondering if they made diffrent heads for the model c that would have diffrent compression chambers for more or less compression
No. Not a noticable difference from the 38 B thru the end of the CA's. I have removed up to .200 from the heads. The water is quite deep compaired to other makes of tractors.
Here is a picture to see the cross section of the heads.
thanks i think it was all done with the pistons weather they were dished or flat top im trying to get this little c i have set up for a light weight puller for a couple shows for my girl friend and want to get as much snuf out of it as i can
