d15 allis chalmers crankshaft journal size
does anyone have the spec for the standard crank journals on a d15 crank, i"m having it ground but i need to know what spec is so i know it hasn"t already been done once. i don"t think it is a II generation. but if you have both specs that would be greatly appreciated.
Most of the time the guy grinding the wrinkle rod will have the spec's at hand and check, then check again before grinding.
I would be pretty leary of a machine shop that DIDN'T have the spec's available!
Have you asked?
149 gas- mains 2.748" - 2.749", rods 1.936" - 1.937"
172 diesel mains 2.497" - 2.498", rods 1.9975" - 1.9985"
I don't have the specs for the gas 160 at hand. Jerry
