B Allis Starter Conversion
2nfarmer
New User
Just Bought a 1939 B wide front
was wondering if I could buy a different bell housing to add electric start to this tractor
You need a torque tube, flywheel with a ring gear and a starter of course but yes it can be done. I have a few of the parts you would need on hand. Parts from both the B and the C will work. By the way ALL Bs where wide front
(quoted from post at 09:28:19 09/14/11) You need a torque tube, flywheel with a ring gear and a starter of course but yes it can be done. I have a few of the parts you would need on hand. Parts from both the B and the C will work. By the way ALL Bs where wide front
What kind of cost is a guy looking at?
Before you give a bunch a money for a torque tube by its self you could buy a junker C and have the hardware to give you foot brakes. I have seen the whole back end of a C go for 50 bucks and some not a lot above that.
(quoted from post at 10:47:02 09/14/11) Before you give a bunch a money for a torque tube by its self you could buy a junker C and have the hardware to give you foot brakes. I have seen the whole back end of a C go for 50 bucks and some not a lot above that.
Thanks, for your time and info
I have a dozen or so tractors, and " would welcome not having to buy another $80 battery!
Something else to consider: since you do not have a torque tube with a starter opening, you probably also do not have the bosses on the engine block for mounting a generator. If that's the case, and you want to add charging capability, you'll need to cobble together some non-original method of mounting a generator or alternator - or replace the engine block with one that has the bosses. You'll also need to cut the toolbox back to make room for a battery. Or locate the battery someplace else. It all can be done. Only you can decide if it's worth it.
Have torque tube.
I be in iowa can deliver west if close to my route, let me know if interested email is open.
Ralph
