Company Logo (800) 853-2651 Shop Now
Starter activator on dash of a 49 WD
Farmallb
09-02-2011 15:09:02
My boys has a key. There are 3 holes in the (dash)? 2 are around 1/2in and one is 1in. What went in those holes besides what activated the starter. Was it a key or button. If button was it black or silver, metal or rubber? Thanks guys.
Aaron SEIA
09-04-2011 17:33:58
 Re: Starter activator on dash of a 49 WD in reply to Farmallb, 09-02-2011 15:09:02
Per the AC parts book. Tractors SN 136317 and lower used a push pull mag kill switch. SN 136318 and up used a key switch and a distributor. Left hole is for the light switch, right hole is for push pull or key switch.
AaronSEIA
Farmallb
09-04-2011 13:43:26
Will Somebody tell me, IF the WD came out with a key switch or not, My boys has got a key switch on it. I dont know if it origionally HAD a key switch, or if somebody just put that on it.
NOW, as I understand what somma uve been saying. One of the smaller holes in the dash was for the light switch, and one was for the kill switch on the mag. AM I RIGHT ON THAT PART????? Thanks.
Farmallb
09-03-2011 15:55:51
No one has, as yet, stated that the WD came out with a key switch instead of a push button starter switch. The push pull switch is for the lights and mag also, I thought. Its a 2 or 3 way switch. Will someone tell me what went in each of the 2 little holes and what went into the big hole on the (dash)??
BushogPapa
09-02-2011 21:02:29
If this one has a "Key", you do need to look it over and see what all has been changed on that WD.. Originally, the WD had NO Key, only the Push-Pull switch for "Run" or "Off".... Does it still have a 6 Volt Battery, Positive Ground..? Many have been converted to Negative Ground and 12 Volts.. You need to know which it is..!! Ron.
steve(ill)
09-02-2011 18:43:13
the original light switch had a resistor to ground that was connected to the "F" terminal on the generator. This made the generator charge at different rates if the lights were on, or off. There is no voltage regulator or current regulator on a 6 volt system.
ohio
09-02-2011 15:36:30
key switch underneath, light switch/ genny cutout on top, ammeter. Starter rod is one on right under steering wheel. Choke is on left. Had a mechanical contact on starter, no solinoid.
Farmallb
09-02-2011 16:04:20
 Re: Starter activator on dash of a 49 WD in reply to ohio, 09-02-2011 15:36:30
Yes its got the 2 starter and choke rods on it, but the (dash)? I mentioned, is laying loose. I bought a push pull switch for it It has a key switch on it. What is a generator cutout on top?
ohio
09-04-2011 09:44:08
 Re: Starter activator on dash of a 49 WD in reply to Farmallb, 09-02-2011 16:04:20
forgot about the ground for the mag, it's a momentary on some i've seen. and the light switch isn't really the cut out for the generator, but it controls high/low charge.
chalmersbob(pa)
09-02-2011 19:03:52
a WD will have the resistor light switch and a push pull grounding switch for the magneto in the dash box. The cutout is on top of the gennerator. Great little tractor. Bob
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: WANTED looking for vintage Brake & Clutch riveting machine . Please provide pictures with details . Foot operated or ??? Please advise JJB [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
