Company Logo Shop Now
Electrical wiring Question On CA Up Date
KCTractors
08-17-2011 15:37:39
Thanks for the help so far, it was wired all wrong, but I still can't get to charge. If I by-pass the cut-out, it will charge full bore. I put a new cut-out in and still the same. The cut-out will not close to charge, if I push the contacts closed, it will charge, but will not stay closed. What should I look for?
John T
08-17-2011 16:04:16
 Re: Electrical wiring Question On CA Up Date in reply to KCTractors, 08-17-2011 15:37:39
The Cutout wont work unless its well grounded, try a jumper wire from its metal case to a known good clean frame ground......
If she charges strong if you by pass jump across the cutout (wire BAT to GEN/ARM) that tells me the genny is okay and the problem is the relay isnt latching in cuz its just BAD or its not grounded.
Is it the correct polarity to match the tractor i.e. Pos or Neg ground???
Run through my Troubleshooting Procedure
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
John T
steve(ill)
08-17-2011 15:56:31
the contact closes when generator output is higher than battery voltage. i would guess you generator is not putting out much ??
steve(ill)
08-17-2011 15:59:13
 Re: Electrical wiring Question On CA Up Date in reply to steve(ill), 08-17-2011 15:56:31
try grounding the F terminal and see if that does anything...
third party image
Latest Ad: Farmall 450 400 factory wide front End, nice tight front end, no welds, 1250 obo [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
