Guys, I recently changed over my second allis to the pertronix electronic ign. Both tractors wd45's. The first I did this spring works great. This tractor had been all gone thru and restored a few years ago and its 12volt neg ground with the genny. The second conversion I did a few days back on an old work tractor.It too is a wd45 12volt neg. ground with the genny. Both conversions included the 12volt coil(flamethrower) and the newer style plugwires recommended for the conversions. Now the problem with this second tractor is every few times when I start it it dont seem to be firing on all cylinders,it will lope cut out and sputter sometimes dying,it will sputter so bad you will think its already died then it will cough and lope again-if I increase or feather the throttle up it will usually "catch" then take off an run like a scalded dog. Next time I start it it takes off fine with no sign of trouble. I have tryed the test of runnin the jumper from the hotside of batt. and hooking straight to the coils hotside and it dont really make a diff. I have checked the ground of the module plate in the bottom of dist. and it checks good. I was wondering if any one had any other things to test-try. I pull this ol gal once in a while and was wantin the extra I could get out of her with the elect. ign. but Im about to throw the points back in this one till I can get around to a complete restore. Thanks for any help, Hoss
