Company Logo Shop Now
WD-45 head, manifold surface
S.C.
07-30-2011 11:31:09
I recently had a valve job done on a head for a WD-45 I'm restoring. When I put the manifold on I noticed a large gap between the head and manifold on the outside exhaust ports. When I checked both with a straight edge the head was off more than the manifold. The manifold is being planed flat. Is there anything similar to epoxy I can build the head surface up with that will withstand the heat? I should have checked this before I bolted the head on. I've been told MIG welding is the best thing to do and have it machined flat again. Or just try using more gasket on the ends. I'm probably not the first guy to have this problem so I thought I'd see what some of you think. Thanks.
ohio
08-01-2011 17:03:42
 Re: WD-45 head, manifold surface in reply to S.C., 07-30-2011 11:31:09
I set the head up on the horizontal mill & took a clean up. I recut the manifold, I'm fairly sure the intake ports are supposed to be about .020 higher than the exhaust. If the exhaust leaks, no big deal. If the intake leaks........
Wierd Harold
07-30-2011 18:42:10
I've encountered the same problem restoring a couple of D17's. I was sucessful in finding a machine shop to mill the manifold mating surface. Milling appeared to me to be the only option because of the recessed area where the manifold mates. They really turned out well.
Sid
07-30-2011 13:42:05
I used JB or some kind of epoxy. It held for awhile. Not long enough to make it worth while.
Mike Bock
07-30-2011 13:07:01
i have brazed the head up before and filed it flat again worked good but head was off tractor if you are real good could probably do it on tractor with out pulling head , probably would be best to go and pull the head and do what you should of done in the first place jb weld might work but i doubt it would handle the heat
D.D.S
08-01-2011 12:12:36
 Re: WD-45 head, manifold surface in reply to Mike Bock, 07-30-2011 13:07:01
Attn. Mike Bock, my grandparents last name was Bock, Jacob Bock. And i'm interseted in where you are from because it would be nice to know your location.
little willy
08-04-2011 19:21:55
 Re: WD-45 head, manifold surface in reply to D.D.S, 08-01-2011 12:12:36
i live in s IL by mt vernon my great grandfather lawrence Bock lived in Colorado for a while
Bob Bancroft
07-30-2011 11:44:41
I have used more than one gasket on the ends, plus a little high-temp. silicone to try to hold things together.
MN Mike
08-01-2011 05:11:44
 Re: WD-45 head, manifold surface in reply to Bob Bancroft, 07-30-2011 11:44:41
Ditto to Bob's post. I doubled up to make up the gap on mine. That seemed to be enough to fill the void, seal things back up and not break the bank doing it.
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
Latest Ad: McCormick Deering 22-36 Tractor has been restored by previous owner. Runs great looks great. Tractor has automotive paint that is really sharp. Tractor shows really well. Would make a nice addition to a IH collection. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
