AllisG
Does anybody know if there is sombody in Northern Indiana that would be able to fix an allis G clutch? would also go to Ohio and illinois.
Be sure to remove the flywheel and have it refaced. Otherwise the clutch will likely not adjust properly when it is reassembled.
well i added a new clutch, pressure plate, and throw out bearing and it goes into gear good but if you drive it off graval or concrete it starts to slip. Iam just looking for somebody with more knowledge about this then me.
Learned the hard way on my G, do not, I repeat do not install the pressure plate as with factor settings. Reset the adjustments per the G book. On the other hand I am getting pretty fast at pulling the engine. Russ
when it comes to adjusting where do you measure from? when the fly wheel and pressure plate r installed how do you masure at the flywheel
Per page 25 of the manual...Adjust the clutch release levers until they are exactly 1-25/32 from the face of the flywheel, or 11/16 from the release lever contact surface to the back plate. Russ
(quoted from post at 05:31:59 07/31/11) Per page 25 of the manual...Adjust the clutch release levers until they are exactly 1-25/32 from the face of the flywheel, or 11/16 from the release lever contact surface to the back plate. Russ
ut how do you measure from the face when you cant get a measurer on it.
