Bobby (MI)
New User
I need some help with my C. I have tried everything. It will start and run at idle but you can hear a little miss. As soon as I put it under power it starts missing really bad and stalls. It is distributor ignition.
When I was checking the timing tonight, the timing light would intermittantly not light every few revolutions, so obviously it is not firing all the time. The "Fire" mark was also jumping back and forth in the observation hole
I have changed the coil, condenser, plugs, wires, rotor, cap, and updated the wiring.
Before I decided that it is likely an electrical issue, I swapped to a known good carb and drained the gas and put fresh in.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
