Curt south of K.C.
Old
You posted you make your 3 point hitches for the WD's. What do you use for your center link connection? Do you use a bracket around the shaft of the arms? I think that is the rock shaft not sure what you call it?? mine was like that didn't work to well so i made a bracket to bolt on the rear end houseing, sets my center link a little higher more level & it works little better. Just curious
Curt
Curt
