Guys, Im workin on my Pa's old 36' unstyled WC an im currently tryin to fix a front end wobble that it has when you get her up in road gear. If you keep it at half throttle its ok but bump her up another notch and she starts the back an forth wobble. The steering wheel dont wobble at all it stays good an tight.Also the steering wheel dosent have much side to side "play" in it. When I lifted the front end and grab the front wheels there is 1-1.5" of free play before the it moves the steerin wheel.I took the plate off the front end and looked down on sector and worm gear mesh and it is pretty good an tight. Is it possible the bearing/bearings on the sector shaft is causing this? Also my book shows a lower bearing but no upper bearing but makes mention of an upper bearing, is there one or two? Sorry for the long post but was lookin for some info on this problem and maybe the proper way to remove the sector shaft. I think after removin sector gear you just pound it down an out but wasnt sure. Thanks for any help, Hoss
