allis chalmers D-12
DoubleBFarms
New User
I have a allis chalmers D-12 that has a 3 point arms will not go down. Will raise O.K. Shut tractor off push lever down and arms will not go down when I try to push them down. Still like they are under pressure yet. Is there a check valve not releasing. Thank You
Have you checked the relief valve? Sometimes a broken spring, or frozen ball will cause that, also if the tractor has traction booster, it might be in the wrong position.
