Anonymous-0
I have recently accuired an Allis D-10 w/ 3 pt hitch and a full set of cultivators. The pto always spins. Sitting on the seat there is a lever on the right hand side that looks to go to the pto, but no matter which position i put the lever in it still spins. any ideas?
Know what serial # you have? On the late model ones, there is a brake, that holds it stopped. If someone uses this brake, to try to stop a heavy rotating flywheel, they can wear out the brake prematurely.
This is normal. The PTO clutch is an oil type and runs inside the gear box. The PTO is spinning because the oil is circulating and causes the clutch to sort of move with the oil. It is not engaged to do work until the lever is pulled to force the clutch plates closed. I think they cover this in the operators manual.
