jumps out of gear
If you want to do an inspection first, pull the shifter out and then take the plate that is on the side to the right of the shifter. The rails and forks are on the back side of this plate. Possibly they are worn?
Thanks, I will take a look at that, the shifter doesn't move as for going into 3rd as it does in the other gears.
