Steering play in 49 B??
Hossman
Fella's My little 49 B has alot of play in the steering. Is this something I can adjust out or is a rebuild-replacement the way to go? Thanks for any advise. Hoss
Probly find the problem here.
Should look like this.
You will likely need to replace the "Pin" on the sector shaft. The old one must be drilled out, very hard steel. then you can get the Pin on ebay or from John Deere for an M tractor Part # AM1515T, and put it in the hole you drilled. If the worm gear is bad, you will need to find one, not easy to find a good one.
Bill B
Guys, Thanks so much for the info. Very helpful w/the parts no. Dick, the pictures were great! Thanks again! Hoss
