Re: ALLIS 200-wont go
rod bender
02-27-2000 05:29:20
Dean, it sounds more like somthing in the transmisson went haywire, if the rear end locked up both wheels would slide when pulled. my 4.04% worth.
Dick L
02-27-2000 07:26:29
 Re: Re: ALLIS 200-wont go in reply to rod bender, 02-27-2000 05:29:20
Is this with the clutch down? Is it in or out of gear? If it does this only with clutch up what gear is it in. If you can it pull ok with the clutch down then it is ahead of the clutch. If your trying to pull start it in a low gear this will happen. More information is needed for us to guess at your prblem.
