Allis Question!
LenND
What was the first Allis tractor to come from the factory with a distributor? Not a magneto.
The B/C at one time the mag/distributor form what I understand was an option so you could have what you wanted.
WD had the battery (distributor) ignition in 1953, at sn 136318. Also, all WD45 tractors. CA battery ignition started at engine sn CE149841. Model B started the battery ignition in 1953, tractor sn 123996.
The really late wd's came from the factor with a distributor not the adapter plate to change from a mag. The G was the first standard equipment. The WD-45 a Mag kit was a option but generally was a distributor. The CA's came with a distributor.
