Company Logo Shop Now
WD,WD-45 Hand clutch.
JMD
06-08-2011 05:26:20
I herd that the hand clutch was the weakest point on the WD WD45s, is this true? Thanks JMD
ohio
06-09-2011 18:04:08
 Re: WD,WD-45 Hand clutch. in reply to JMD, 06-08-2011 05:26:20
Even the two disc units are plenty strong. The three discs will lock up at least a hundred hp. The pto will not transmit that much.
hd6gtom
06-09-2011 12:25:54
JDM I think you were told wrong, in everyday use they are almost impossiable to destroy. Are you confusing the AC with IHC????
David Grubb
06-09-2011 07:58:28
If your WD has a stock 2 disc hand clutch unit and your engine has been upgraded to WD45 power your hand clutch unit should have been upgraded to a 3 disc WD45 stock unit.
Tom Stenerson
06-08-2011 12:12:56
Used one baling and combining for 25 years,no problems!!!
jd plowboy
06-08-2011 11:03:40
if you are going to pull these tractors the hand clutch is the weakest part. the first thing to get rid of when making a puller cause if you build much power it will slip. take it out and couple it back together
theothergreenguy
06-08-2011 10:09:19
That is incorrect, the PTO is the weakest part. Do not use a hardened shear bolt
JMD
06-08-2011 11:19:35
 Re: WD,WD-45 Hand clutch. in reply to theothergreenguy, 06-08-2011 10:09:19
See what I was told that if you use it to much it will break .
BushogPapa
06-09-2011 19:51:23
 Re: WD,WD-45 Hand clutch. in reply to JMD, 06-08-2011 11:19:35
Never had a problem with a PTO in a WD-45..BUT...
You MUST NEVER try to engage the PTO unless you are standing still AND have the transmission IN GEAR 1st...
Most are damaged by grinding the gears, trying to put it IN gear...Breaks the gears, or the Ears off the lower Idler, above the driven PTO gear..
Ron..
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
