Allis b sickle mower
rdrash
Hey guys, Does anyone have a parts picture and part numbers for a sickle mower on a 1952 allis b. I have so much play at the pitman arm (I think that's what it is called) on the front where the shaft is and it knocks pretty hard. Thanks for any info.
Trevor
i have an electronic file of the sickle book. send me a e-mail and i can send you a electronic copy.. most of the clearance i have is in the ball socket and wood arm area. I have to sand down the wood bar width to make the ball brackets squeeze a little tighter on the ball. i use selastic nuts on the bolts thru the wood bar. Tighten so you have just running clearance on the ball... use plenty of grease on the ball and oil on the sickle bar. [email protected]
Is it the belly mount or the rear mount one?? If it is the belly mount I have the manual on the computer and I can send you it if you send me an e-mail first. It has a pretty good parts brake down and is a lot of help
